"Error occurred while applying DataStreamSimulator"
Dear all, I have little experience in using DataStream Plugin, I met problem to apply it.
The following is xml of my setup and Error Message Met:
<operator name="ExampleSource" class="ExampleSource">
<parameter key="attributes" value="C:\Program Files\Rapid-I\RapidMiner-4.2\streamtest"/>
<operator name="DataStreamSimulator" class="DataStreamSimulator" expanded="yes">
<parameter key="data_stream_names" value="a b"/>
<parameter key="data_stream_relevance" value="a b"/>
<parameter key="number_of_batches" value="2"/>
<operator name="BayBoostStream" class="BayBoostStream" breakpoints="before" expanded="yes">
<parameter key="batch_size" value="3"/>
<parameter key="keep_example_set" value="true"/>
<operator name="NaiveBayes" class="NaiveBayes" breakpoints="before">
Error Message:
"Process Failed
ClassCastException caught:
com.rapidminer.example.set.RemappedExampleSet cannot be cast to com.rapidminer.example.ConditionedExample"
May I know how I can get correct setup? Thanks!
Comments
There are no comments yet
