if(confidence(1) > threshold) then 1else 0
<operator name="ModelApplier (3)" class="ModelApplier" breakpoints="after"> <parameter key="keep_model" value="true"/> <list key="application_parameters"> </list> <parameter key="create_view" value="true"/> </operator> <operator name="failConfidence" class="ConditionedFeatureGeneration" breakpoints="after"> <parameter key="attribute_name" value="fail1"/> <parameter key="value_type" value="integer"/> <list key="values"> <parameter key="confidence(F)" value="prediction = F"/> </list> <parameter key="default_value" value="0"/> </operator>
