Tobias Malbrecht wrote:Hi,yes, in principal the weights created by the [tt]EqualLabelWeighting[/tt] operator should sum to 1 with the default parameter values. Did you check if the error occurs also when you set the [tt]total_weight[/tt] parameter to value greater than 1? Perhaps the weights do not sum exactly to 1 because of rounding errors?Regards,Tobias
