how can I see the convergence criteria in optistruct output file? Is there any control card to set that.? Also I am running a topology optimisation of the wheel disc. I have taken a static analysis and I have a load case where there is a load acting in only one direction. In the analysis I have the max stresses in the applied direction only, ie at only one ventilation hole edge. So while moving to optimisation how can I set this stress distribution throughout 360 degree of the disc? Can I use extrusion constraint and define a node path in a circular direction? I already used it but wanted to make sure if this is the right way.
Thanks,
Punith Guptha
