What file size limitations exist?
Nico Chart_21517
Nico Chart_21517
edited October 2024 in Altair RapidMiner
File size restrictions are influenced by both the computer operating system and the bit-ness of the application being used. 32-bit Altair SLC has a much smaller address space than 64-bit Altair SLC.
The total number of observations generally allowed in a WPD format dataset is controlled by two system options OBS and WPDHUGE. The WPDHUGE option affects any WPD-format datasets created whilst it is in force. A dataset created under NOWPDHUGE will probably be limited to (2^32)-1 observations. You can check your current settings using:
proc options option=obs; run;
proc options option=wpdhuge; run;
WPDHUGE is not set by default due to the effect it has on the size of index files because 64-bit record pointers are required.
You can either test a particular job locally using:
OPTIONS WPDHUGE;
Or add –WPDHUGE to a altairslc.cfg file for a more permanent setting.
Log files and CSV files are sequential output files and can be as large as the operating system allows.
Welcome!
Welcome!
