Each design project is associated with one vovserver. The vovserver is started at the beginning of the project and normally runs until the project completes.
Each project goes through a life cycle. It is first created and then enabled in your shell. At that point, the user can build or load pre-defined flows using Linux commands or Tcl files containing FDL (Flow Description Language).
