In this document, Hyperelastic analysis using OptiStruct is presented with a comparison of different material models and 4 applications involving Hyperelastic material.
Details are given in the PDF file that is separately attached.
Since animations are not included in the PDF file, they are embedded in the article body here.
Similar titles as used in the PDF are used here so that the reader can easily identify the animations.
Single Element Virtual Tests
Rubber Ring (Ogden N=3, All Three Treloar Test Data)
Axisymmetric Rubber Seal (Ogden N=3, All Three Treloar Test Data)
Solid Rubber Tire Compression (Ogden N=3, All Three Treloar Test Data)
Rolling Fatigue Virtual Test (Ogden N=3, All Three Treloar Test Data)
