OptiStruct Contact Using ALM Method
Updated by Mohan Parthasarathy
Four examples are presented in this document to demonstrate OptiStruct contact using ALM (Augmented Lagrange Multiplier) method in implicit nonlinear static analysis.
1) Rubber Ring: Compression of a ring made of a Hyperelastic material in excess of 100% strain, involving self-contact
2) Wedge: Large deformation of a plastic part resembling a wedge
3) Solid Rubber Tire Compression: Involves compression of solid rubber tire on a metal wheel
4) Rolling Fatigue Virtual Test: Virtual simulation of the rolling fatigue test using a simplified model
Details are given in the PDF file that is separately attached. Since animations are not included in the PDF file, they are embedded in this article body.
Similar titles as used in the PDF are used here so that the reader can easily identify the animations.
Rubber Ring - Step1 & Step2 Animation
Rubber Ring - Step2 Animation
Wedge - Animations
Solid Rubber Tire Compression - Animations Animation shown with X-Section Cut
Rolling Fatigue Virtual Test - Animations
Comments
No comments on this post.
