Introduction
Altair PBS Professional is a fast, powerful workload manager designed to improve productivity, optimize utilization and efficiency, and simplify administration for HPC clusters, clouds, and supercomputers. PBS Professional automates job scheduling, management, monitoring, and reporting, and it's the trusted solution for complex Top500 systems as well as smaller clusters.
The PBS Professional scheduler provides many different methods for optimizing scheduling. Placement sets, also referred to as topology-aware scheduling, can be used to group nodes together based on a shared characteristic to help optimize job performance as well as the overall use of your PBS Professional complex. Common usages include taking advantage of interconnect or hardware topology including IRUs or racks, system resources, access to shared storage, system location, and application availability.
Challenges
You may have a variety of system resources under the control of a single PBS Professional scheduler and many jobs trying to utilize those resources. Improving application performance and maximizing system performance is a key benefit of using placement sets. A placement set can take advantage of interconnect and hardware topology to minimize hops and message latency for MPI-type applications by scheduling multi-node jobs on nodes that are topologically close to one another.
Using placement sets allows you to run a job on a set of nodes that share a common characteristic, but the user doesn't need to know what the value of that characteristic is. For example, you want all your nodes running a job to be on the same switch, but you don’t care if it's switch "A" or "B." Or you want all nodes of a job in a heterogeneous cluster to have the same processor type, but you don't care if that type is "Intel" or "AMD."
The primary advantage of using placement sets is that while users can request specific placement sets, they do not need to know hardware details to obtain optimal job placement.
Definition of Terms
• Vnode – A virtual node, or vnode, is an abstract object representing a set of resources which form a usable part of a machine. This could be an entire host, a nodeboard, or a blade. A single host can be made up of multiple vnodes. Each vnode can be managed and scheduled independently. PBS Professional views hosts as being composed of one or more vnodes.
