May I ask if the back of the wall is composed of PEC in an urban scenario with 3D ray tracing? As shown in the figure? Since if in the settings, the 3D IRT simulation in an urban scenario does not consider indoor coverage, then the rays will just reflect on the surface of the building walls. And all the buildings are wrapped in a material with some thickness. So if without considering indoor coverage, the back of the building wall (behind the material) is PEC and rays will go through the material and reflect perfectly from PEC? I would be grateful if you could answer my question.
