how to define a marker motion correclty
Nicolas_20776
Nicolas_20776
edited September 2024 in Community Q&A
I try to control the motion in global X for the red cylinder (which has contact to the gray arm).
"Marker 0" is fixed to the cylinder and want to give a velocity in X. But no matter what velocity i give (even when i give "0") the cylinder motion is only driven by the contact and the gravity.
Is there a guideline how to apply marker motions?
Thanks
Nicolas
Welcome!
  • GTT Adam
    GTT Adam
    Hi Nicolas,
    You can learn more about defining motions with markers here:
    https://help.altair.com/hwdesktop/hwx/topics/chapter_heads/motions_r.htm?zoom_highlight=motion
    Also, this constraint will only effect the TX axis, so the object is still free in TY, TZ, RX, RY, and RZ.
    Hope this helps!
    Adam Reid
  • Nicolas_20776
    Nicolas_20776
    The marker motion x=0mm should prevent the cylinder tor roll down:
    ...but it has no effect.
    And  i can not see any error or warning in the .log file....
    What is wrong with MotionSolve or my setting?
    find the .mdl attached.
    Thanks for you help
    Nicolas
  • GTT Adam
    GTT Adam
    Thanks for you help
    Nicolas
    Hi Nicolas,
    If you want to constrain the cylinder to only move in the Z axis, you can create a translational joint that connects the cylinder to ground.
    If you want to allow translation in in the Z and Y axis, then you can instead create a planar joint.
    If you would rather use the Motion method, then only a few changes are needed:
    1. Create a new marker attached to ground at the same location as Marker 0 (Point 6).
    2. Change the Motion definition to instead use the marker on the cylinder as the first marker and then new marker as the second marker:
    Hope this helps!
    Adam Reid
  • GTT Adam
    GTT Adam
    Hi Nicolas,
    Hope this helps!
    Adam Reid
    Hi Nicolas,
    If the above reply answered your question, please make sure to mark it as Correct so other Users may be able to find the answer easily.
    Thanks,
    Adam Reid
  • Nicolas_20776
    Nicolas_20776
    can any one help me here do define a correct marker motion please?
    Thanks a lot.
    Nicolas
  • GTT Adam
    GTT Adam
    Thanks a lot.
    Nicolas
    Hi Nicolas,
    I already modified your model to provide the requested Motion.
    It was attached to my previous post.
    If you are unable to see it, make sure you are Showing all Replies (button at top of this page).
    Hope this helps!
    Adam Reid
Welcome!
Welcome!
