Hi
I want to use pulse waves of different periods to test the issue of vibration and noise of a stepping motor, so I designed the pulse wave as shown below.
Originally, the pulse wave was generated by the statechart method, but the accuracy seems to be too low and once the timestep is adjusted to 1 microsecond, GIOP cannot send the signal normally.
Is there any way to accurately generate a customized pulse?
Thank you very much
