I've simulated a Formula-Student Monocoque using Optistruct. I wanted to get an idea of the general stiffness of the desing, so i did not create a laminate yet, but used a 5mm steel sheet to simplify the first model.
How can i display the "twist"angle of the chassis over the x-axis?
Thank you in advance!
