I am getting an error of negative inertia on node. I have switched on the implicit option by entering the key words in the radios engine file. When I perform the same in the explicit mode, no error comes and the simulation runs smoothly. On checking the nodes by ID I can see that these nodes are on the master contacts surfaces of TYPE 2 contact. Attached file has snapshot of error message.
Kindly let me know about the same.
