Altair® Panopticon™ Tutorial: How To Join Data Sources
User: "Hugh_R_Heinsohn"
Updated by Hugh_R_Heinsohn
You can join data from two or more sources when you load it into Panopticon. This applies to streaming real-time data sources as well as static, historical datasets. Simply put, Panopticon enables you to blend data on-the-fly without using an external database. When joining data sources, you specify the type of join you want and the columns you want to use as join keys. You can use columns of any data type and any number of key columns for your joins.
This video demonstrates examples for each of the join types.
Comments
No comments on this post.
