Dear Sir,
It is likely to be a syntax error. Try copying the X_Traction using Right Click (Surface > Surface Name > x_traction)
Thank you for your valuable support
kindly give suggestions how to get the result for the entire span of the wing (Cl , Cd and Cp )
Thanks
Ram
I suggest you contact your local support office on this to get direct assistance. The error 'global name e is not defined' doesn't seem consistent with your formula. One thing you could try is to separate the operators, etc, by a space, and also use reals instead of integers - to see if that makes a difference.
