When you create a new NetworkComputer queue or a new FlowTracer project, each time, the system creates a registry entry and directory in the SWD. At a certain point, you may have hundreds of these. While these projects do not affect performance, they can clutter things up and take up much needed space. It's best to do some clean-up.
To get a list of available projects, run the following command:
vovproject list
This will show you all the projects and their owners.
To get a list of all projects known to your Runtime installation, run the following command:
vovproject list -a.
In the following example, there are eight different projects that were created.
~:vovproject list
PROJECT OWNER HOST PORT STATUS
1 licmon-1503 ybouvron ybmac 1234 running
2 licmon3 ybouvron ybmac 2222 obsolete
3 licmon ybouvron ybmac 5557 running
4 licmon_1509 ybouvron ybmac 5559 running
5 licmon ybouvron ybmac 5557 obsolete
6 trunk ybouvron ybmac 9058 stopped
7 vnc1603 ybouvron ybmac 6217 obsolete
8 vnc ybouvron ybmac 6271 running
9 vnc_u2 ybouvron ybmac 6277 stopped
There are three different statuses:
- Obsolete: Projects that are running but have a timestamp older than 1800 seconds.
- Running: Projects that are up and running.
- Stopped: Projects that were stopped by an admin or owner of the tool.
To remove a project, be sure it's in the stopped state. To stop the project, run the following command:
vovproject stop <name>
To remove the registry entries along with the swd directory and all its content, run the following command:
IMPORTANT: vovproject destroy is irreversible. If you need the project again, you will have to restore it from backup or re-create it. Consider using the vovproject archive subcommand instead.
vovproject destroy <name>
