running tcl file from dos
Marion_20756
Marion_20756 Altair Community Member
I have a tcl file for exporting a jpeg in Hypermesh that I want to run from dos using the command:
C:/.../hmopengl.exe -tcl filename.tcl
It runs without any errors, only the exported jpeg file is completely black. The command I used in de tcl file for exporting jpeg is *jpegfile.
When I remove *jpegfile from the tcl file and place this command into a new tcl file, run the old file (without *jpegfile) using the above dos command and then run the new file (containing only *jpegfile) from Hypermesh (using File -> Run -> Tcl script), the output looks ok.
Does anyone know what the problem is?
Marion
  • Altair Forum User
    Altair Forum User
    edited May 2011
    problem maybe because of time delay, try putting a time delay before the *jpegfile command, like sleep 60
    - cae.developer@gmail.com
Welcome!
Welcome!
