Overview
Obtain new components with the 2d faces of the selected 3d components. Optionally assigns thickness to the 2d element faces, for OptiStruct and Abaqus profile.
Run the script, select components and thickness. New components with the 2d elements will be created. If thickness is not equal to 0, a property will be assigned to these elements.
Limitation
Thickness only for Abaqus and OptiStruct profile. Not tested for others.
Interface
