I am unable to create 2 RBEs, with both using the same surface as slave.
Error mesage that I get is:
Unable to create RBE element
INFO: 1) Nodes may be used by other connecton objects (or)
2) Due to radius specifies.
How to solve this?
Thank you!
can you clarify what are you trying to accomplish with 2 RBE2s in the same face/nodes?
This is probably been blocked due to kinematic incompatibility that would be created.
The same node cannot be dependent of 2 different RBE2 element. Creating 2 RBE2 in the same face would result on that (except if different DOFs were selected)
Do you have a reason for creating this?
