🎉Community Raffle - Win $25
Join and Win
Select Gage Design Variables by Property for Dlink
User: "Chayan"
Updated by Chayan
Overview
Linking two design variables with the dlink panel can be very tough if you have many design variables. You can only select them in the panel area and the names are cut off if they are too long. However if your design variables are all gage design variables then their names are simply the property names with a g infront of them. This allows you to select the design variables by their property. Since you can select properties visually it makes linking many design variables much easier.
You fist select the independent property, then the property that will have the same design values.
Limitation
You cannot link multiple dependent properties.
Functionality
Model/Analysis
Subfunctionality
Optimization
Interface
OptiStruct
Comments
No comments on this post.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
