Overview
Process of Converting OptiStruct Freeze Contact into Radioss TYPE2 Interface.
First, invoke "OSDelNonFreeze.tcl" to delete all CONTACT cards which doesn't have FREEZE type.
Second, convert OptiStruct to Radioss via "Tools -> convert -> OptiStruct -> To Radioss".
Last, invoke "GroupUpdate_AfterOpti2RadConverion.tbc" to make all /INTER/TYPE2 cards.
Limitation
An OptiSturct model should have CONTACT with TYPE=FREEZE. TIE cards are not allowed. In /INTER/TYPE2, a slave node set is defined by /GRNOD/NODE and a master surface is defined by /SURF/PART/EXT. Spotflag is set to 25 and Ignore is set to 1 in a /INTER/TYPE2.
Functionality
Model/Analysis
Subfunctionality
Model Setup
Interface
OptiStruct, RADIOSS (Block)
