Overview
This macro allows you to open a hole on a surface by entering a diameter and selection a point. You can create multiple holes of the same diameter for each point you select. The holes are created normal to the surface at the point you selected.
Run the script and follow its directions.
Limitation
Currently, I still haven't been able to write logic that can differentiate the new surface from the original surface in some scenarios. Therefore I added an extra step at the end that allows you to review and modify the surfaces (circular holes) that will be deleted from the original surface.
Functionality
Geometry
Subfunctionality
Creation|Editing
Interface
No Specific Interface
