Overview
This macro will create washers for the selected surface holes (geometric holes) in the model. The scale factor for the first washer = 1.5 * Radius of the hole. The scale factor for the second washer = 1.75 * Radius of the hole. The scale factor for the third washer = 2.25 * Radius of the hole (Scale factors are hard coded which can be easily modified.)
The user would be asked to select hole edges.
Limitation
The edges should represent complete hole circumference. The Scale Factors for washers is hard coded in the script. (As per Customer's Request)
Functionality
Geometry
Subfunctionality
Editing
Interface
No Specific Interface
