Overview
This is only for Nastran/OptiStruct Solvers Converts following entities: # Grid locations # Pbeam, Pbar, PROD, PELAS, Pshell, Pshear # Masses: "mass" # Mat1: Mat1 Material: E, G, Rho are updated # Mat2 Material: G, Rho ,ST,SC,SS are updated # Systems Following unit systems are available : # "m,kg,N" # "mm,ton,N" # "in,lb/386,lbf" # "in,lb,lbf"
1- Load the model to convert
2- Run the macro
3- Select the "current units" and the "convert to" units
4- Clic the "Convert" button
Limitation
Works only for the entities listed in the "description" section.
Functionality
Utilities
Interface
Nastran, OptiStruct
