Update Constraint display
User: "Michael Herve"
Updated by Michael Herve
Overview
when deleting elements from a Constraint, if the Constraint is defined with an element based surface, the display of the constraint is not directly updated, even if the related set is properly updated.
This script updates the display of such modified constraints.
If the Constraint is defined with a node based surface only, Model Checker must be used to remove free nodes
You can load it from File -> Load -> Tcl script
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
