Overview
Only rbe2 or rbe3 connected to solids will be updated with the midnode of 2ndorder elements. Weight Factor of rbe3 shall be updated manually by users. (default is 1.0 at all dep.node(123456) and indep.node(123)) Refer User Message For Any Kind of information While Processing.
Pops up a GUI on running the script. You can select RBE2 or RBE3 elements to update with the 2nd order solid elements.
Limitation
DO NOT TRY WITH SHELL ELEMENTS....!!!
Functionality
API
Subfunctionality
Tcl Commands
Interface
No Specific Interface
