Step Curve
User: "Chayan"
Updated by Chayan
Overview
This script helps you to create a smooth step curve. The curve equation is described as, y(x) = Y0 (x/X1) ^3 (10-15(x/X1) +6 (x/X1)^2) y(x) starts from zero at x=0 and increases smoothly. At the middle area, y(x) increases rapidly. Finally, y(x) bound to the goal smoothly. You can create those kind of curve without this script via post -> xy plots -> edit curves. This script helps you to input the equation correctly.
* Invoke via File -> Run -> Tcl/Tk script
* input the name of the new curve, the last x value and the last y value.
Limitation
It only supports RADIOSS. The curve always starts from (0,0).
Functionality
XY Plots
Subfunctionality
Utilities
Interface
RADIOSS (Block)
Comments
No comments on this post.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
