Overview
INTRODUCTION
Landing gear are employed on most aircraft for ground operations and landings. Engineers must design landing gears to handle the impact loads during aircraft touchdown and absorb the shock of the landing to prevent damage to the aircraft. There are three main types of struts used in the aircraft industry: rigid struts, spring steel struts, and oleo struts. Rigid struts transfer the shock load directly to the airframe. With rigid struts, landing at a high velocity can damage the frame and make for an uncomfortable landing. A slightly more complex but safe option are spring steel struts. They incorporate a spring to transfer the load to the frame over a greater period of time to decrease the shock to the plane. However, the oscillation of the springs can create a bumpy landing. Oleo struts are a clever solution that decreases the shock to the plane and dampens oscillations.
The oleo shock uses two telescoping cylinders. The top cylinder is connected to the aircraft frame and the bottom cylinder, called a piston, attaches to the wheel axle or bogie beam. The top cylinder is filled with air or nitrogen and the piston with incompressible hydraulic fluid. As the piston is pushed into the cylinder, the nitrogen compresses, behaving like a spring. However, it is desirable to have an increasing spring rate and damping to prevent oscillations. To achieve this, engineers put an orifice plate in the cylinder and a tapered rod called a metering pin in the piston. As the piston moves upward, the area for the hydraulic fluid to flow into the cylinder decreases because the tapered rod takes up a larger area in the orifice. This creates an increasing spring rate. The friction from the flowing hydraulic fluid past the orifice plate converts kinetic energy into thermal energy which dampens the system. The oleo strut makes landings easier for pilots and safer for the passengers and aircraft.
Designing an oleo strut landing gear can be aided by using computer simulation. Different orifice plate sizes can be tested to optimize landing performance. Engineers can also test different landing velocities to determine the maximum safe velocity for the airframe and landing gear. In this example, we will build a landing gear model using MotionSolve, a multibody dynamics (MBD) tool. While MotionSolve handles the dynamics, co-simulation with Twin Activate, an intuitive 1D physics modeling software, will allow accurate modeling of the hydraulic system.
Understanding the Model Definition in MotionSolve
First, the MBD model of the landing gear is built from existing CAD data in MotionView.
Understanding the Model Definition in Twin Activate
The Twin Activate model performs calculations for the oleo strut forces using the Modelica library. The oleo strut is represented as a plunger cylinder which carries the entire 20,000 kg mass. Damping depends on the stroke and velocity of the plunger which is realized using a look-up table. Every timestep of the simulation, Twin Activate receives the piston position and velocity from MotionSolve. Twin Activate returns the force on the piston to MotionSolve.
Pre-Requisite
SOFTWARE REQUIREMENTS
MotionView (2024 or newer)
MotionSolve (2024 or newer)
Twin Activate (2024 or newer)
MODEL FILES
MODEL SETUP & SIMULATION STEPS
- Start a new MotionView session.
- Open LandingGear_Archive.mdl
- Export the solver deck for co-simulation with Twin Activate. File > Export > Solver Deck
- Open LandingGear.scm in Twin Activate.
- Double click the MotionSolve block.
- Change the input file to the xml file created by exporting MotionSolve’s solver deck.
- Save the MRF output file
- Select Run to perform the analysis
- Open a HyperView session in HyperWorks.
- Open the result h3d created in the 04_Results folder to review the animation.
- Open the result plt file in a HyperGraph session to plot displacements, velocities, and forces.
Post-Requisite
RESULTS
The motion of the multibody dynamics model can be viewed once the simulation is complete. HyperView allows users to create vectors plots such as joint forces. Users can also create contour plots including flexible body stresses. Stress hotspots can be used to inform design changes.
Wheel Reaction Forces During Aircraft Touchdown
Bogie Support Link Stresses During Aircraft Touchdown
Support Link Peak Stresses
In HyperGraph, plots of all outputs created in MotionView and Twin Activate can be plotted and analyzed. The aircraft velocity curve can provide some insight into the overall performance of the shock. Strut displacement, velocity, force, and pressure are crucial parameters in the analysis of the oleo strut.
CONCLUSION
In this example we built a model of an oleo strut landing gear using MotionSolve and Twin Activate. By utilizing simulation, aerospace engineers can test different oleo shock orifice plate diameters to predict the shock on the airframe and passengers. With powerful post processing tools, information about the strut displacement, velocity, hydraulic pressure and more can be plotted in HyperGraph. Flexible bodies can be used to predict the stresses on landing gear components allowing engineers to validate system performance.
AUTHORS
John Dagg, Systems Engineering Intern
Christopher Fadanelli, Solution Engineer - Systems Integration
Ananth Kamath Kota, Global Technical Manager - Systems Integration
