EDEMpy example: Segregation index in drum mixer
Overview
EDEMpy is a Python library for post-processing and analysis of EDEM simulation data and takes advantage of EDEMs hdf5 file structure. Using the library, it is easy to extract specific data from a simulation deck and process that data in a customizable and reusable way.
In this example the segregation index (SI = 2 -> No Mixing, SI = 1 -> Random Uniform Mixing, SI = 0 -> Perfect Mixing) is calculated for a drum mixer. A script is provided that calculates the segregation index for the mixer over time.
Note: You must run the attached EDEM simulation deck before running “SegregationIndex-Time_Example.py”.
Further Readings
M. Marigo, D. L. Cairns, M. Davies, A. Ingram, and E. H. Stitt, “A numerical comparison of mixing efficiencies of solids in a cylindrical vessel subject to a range of motions,” Powder Technol., vol. 217, pp. 540–547, 2012, doi: 10.1016/j.powtec.2011.11.016.
Once the EDEM simulation is complete, the python script file can be executed from the EDEM Analyst interface (File->Run EDEMpy script). The script will output the graph showing the variation in segregation index over the simulation time. These plots, labeled 'SegIndex', can be found in the same locations as the EDEM deck.
Comments
how can i extract the data of particles axial position inside drum at each time step?
Could you please extend the above code (which calculates the Segregation index) for other binary mixture of particles? I used the script on my own case and it showed errors. I tried to revise the code but couldn't do it.
Also can I get the exact values of the segragation index?
Thanking you very much.
Thanks & Regard
Alice Wang
