Overview
This script will apply a Contour plot and query result values of an element set. These values are written to a .TXT-file.
January 18th 2024:
Script version was corrected as element set label was hardcoded in the procedure. This line 88 was deleted and new script version attached.
Pre-Requisite
NOTE:
To use the script for own result files, these lines in the .TCL need to be edited:
- line 165: defines the contour plot (result type, component, layer, applied elements/components)
- line 166: defines the label of the element set used for query
- line 170: second to last argument ("element.id ...") defines the query string. These are the columns with info that is output to the final .TXT-file.
A description how to get such query string from a manual GUI operation can be found in this article: LINK
- line 170: last argument defines the path to where the query-.TXT-file will be written (this must be edited for the example as well)
Steps to execute:
1. Download attached .TCL / .H3D / .MVW-files and place in same folder
2. Open the session .MVW-file (NOTE: the HyperWorks version the session was saved in, is 2021)
3. Edit the .TCL-file in line 170 and use a valid string for the path, where the final query-.TXT-file will be written (see very last argument the line)
4. Run script from DropDown File > Load > Script
5. See the query-.TXT-file that is written, containing the info defined by the query string in script line 170
Post-Requisite
