I am trying to automate the conversion of preserved node into temp.
Manually we can do like : Analysis ->preserve node-> select node->make preserved
now node preserved. The preserved node can be converted into temp node like: Analysis ->preserve node-> select preserved node->make temp
For automation:
step 1: Need to call Preserved node.
step2: Called preserved nodes need to convert into temp node with *nodemarkaddtempmark command.
I dont know with what Tcl command we can call the preserved nodes for converting in Tcl script. Can any one help?
