Settings for Specific Topology Optimization?
JTan_1
JTan_1 Altair Community Member
edited January 2022 in Community Q&A
Hi, I'm learning to perform topology optimization of a brake pedal. However, I am not getting the intended result (see image below).
I have set my target to reduce volume and weight, and I'm getting a porous like reduction rather than an organic truss like shape.
Do I have to setup a specific optimization control to achieve the first image? Please advise. Thank you.
Welcome!
  • Xiaolei
    Xiaolei
    edited January 2022
    Hi, very probably you haven't defined boundary condition and loads. Usually we need to fix mounting point, then apply loads on the paddle.
    The below is some methods you can try:
    constraint: mass< xxkg
    object: min compliance
    or
    constraint: displacement< xx mm
    object: min mass
    Please also refer to optimization ebook(you can find it from Knowledge Base) and OptiStruct tutorials. :)
    Thanks.
    Xiaolei
  • JTan_1
    edited January 2022
    Thanks for getting back to me Xiaolei. That doesn't help. I'm conducting parametric study and investigating it with Inspire software now, I can only conclude that the geometry and design space influenced the topology structure.
  • Adriano_Koga
    Adriano_Koga
    edited January 2022
    i agree with @Xiaolei Song
    You should first of all review what is your optimization formulation, and make sure what are you asking the software to do for you.
    looks like something is not correctly formulated, from the results.
Welcome!
Welcome!
