Create Dummy Optimization
User: "Chayan"
Updated by Chayan
Overview
Optimization responses can only be used within an optimization. Nevertheless responses like e.g. DRESP2 (equations …) could also be very useful in analyses, e.g. to define derived result outputs. The script is setting up a dummy optimization. One element will be selected and its property will be a designspace. DOPTPRM are modified so that the optimization will give identical results compared to an ordinary analysis.
1. Define responses.
2. Run script (select responses, select one shell elem).
Limitation
currently the dummy designspace only accepts shell elements, which means that at least one shell element must exist in the model
Functionality
Optimization Results Statics
Subfunctionality
Bulk Data Input Results Topology
Interface
OptiStruct
Comments
1 - 1 of 11
    User: "Pedro_Ferreira"
    Altair Community Member
    Updated by Pedro_Ferreira
    Thanks for this useful script.
    Here you have an improved version of it, that extended its features to allow the model to have multiple load cases and select the respective responses for each one. It also contains some fool proof measures to mitigate the hassle of deleting existing collectors with the same as the ones generated by the code.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
