With this set of scripts it is easy and mor comfortable to check references between nodes/elements and systems. Select a system and create tempnodes on referenced nodes and put on user mark. Same other way around. Nearly the same for Spring elements that have an orientation system referenced on the property card.
Model/Analysis
Model Setup
Abaqus
Share your models, scripts, workspaces, and more with the Altair Community.
