Overview
While performing a demo of Material Library in HW through Oragnize browser, there was no way to export each material out of HM as a separate file which was one of the requirements for Material Library Currently one would have to check one material at a time from Entity State Browser and export the materials individually
The current macro would write out each material as an independent solver file which would only contain the material data. The user would simply need to specify the directory and the solver type and it would write out as many files as the number of materials in the deck. Now the user can save different material database in the network directory which others can access.
Limitation
I have made sure most of the attributes are disabled and only material data is exported. If you encounter any other attribute that gets exported along with the material just suppress the output using the command *marksuppressoutput
Functionality
Utilities
