Find edge nodes of meshes and create node sets
User: "Sebastian_Karp"
Updated by Sebastian_Karp
Overview
This script will find edge nodes of a selected component, and creates a node set for each edge loop.
Example is for OptiStruct.
Pre-Requisite
Have model with mesh loaded into HyperMesh.
The script contains set creation for OptiStruct solver. For other solver formats this block in the TCL needs to be edited.
Run script e.g. from DropDown  File > Load > Script
Select Component/s that should be included in edge loop search.
See that for each edge loop a separate node set is created. The script contains set creation for OptiStruct solver.
Comments
No comments on this post.
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
