Overview
Script to export into new H3D file the available results including new ones generated by means of Derive Result functionalities
1. Create a new result type by means of Derive Results
2. Run the script
3. Choose a filename to save new h3d
4. Choose (optional) whether keeping the XML file used in background for result generation
Limitation
Works in Windows environment
Functionality
HvTrans, Results
Subfunctionality
Contour, User Defined
