Save Rigidlink Master Node Id Into Entity Set
User: "Chayan"
Updated by Chayan
Overview
This script create a entity set of nodes. these nodes are the master node (independent node) of the rigid link element.
As the user run the script, it is requested to select the rigidlink elements. As the previous operation is finished the script collects the master nodes if of the rigidlink elements and save them into a entity set, labeled with the maximum id number of the master node found.
Limitation
This script was tested on a simple model (attached into the documentation) on the RADIOSS V12 profile at HWdestop13.0.103hotfix update.
Functionality
Model/Analysis
Subfunctionality
Model Setup
Interface
RADIOSS (Block)
Comments
1 - 1 of 11
Share projects with the Community
Share your models, scripts, workspaces, and more with the Altair Community.
New Exchange Project
