Overview
Generate Shapes without using the HyperMorph.
From the menu bar, select File -> Run -> Tcl/Tk script. Select the .tbc file.
Functionality
Meshing, Model/Analysis
Subfunctionality
1D Meshing, 2D Meshing, 3D Hex Meshing, 3D Tetra, Meshing, Acoustic Cavity, Mesh Editing, Model Info, Model Setup, Morphing, Optimization
can you share small demo on how to use this script?
