Creates Beam elems spiders for the holes within given tolerance. Can add the nodes to be removed from selection after identifying the holes and re add the nodes. It creates a new collector with spiders.
Meshing
1D Meshing
LS-Dyna
I am running this on a shell mesh and it's freezing up after it's done. Does anyone else have that issue? I'm using HW2022, with the Optistruct suite. Is that why?
Are there any other good tools for building spiders with the use of BEAM/BAR elements for use with Optistruct? It's quite specific I know.
Share your models, scripts, workspaces, and more with the Altair Community.
