Similar to the Linear Cohesion model, the Linear Cohesion V2 model modifies the contacts by adding a normal cohesion force, and can be added “in addition” to other base contact models.
Attached is the source code for the Linear Cohesion V2 model using version 3.3 of the API as well as an example simulation. Please note this is an additional model. To use this model please select a base model and rolling friction model in addition to the API plugin.
The source code consists of the CPU-API code updated to version 3.3 and the CUDA API code supplied as the file CCohesionV2.cu.
This model needs to be compiled into a .dll or .so. Please see the following tutorial:
or the EDEM Help:
https://help.altair.com/edem/topics/programming_guide/introducing_the_programming_guide_c.htm
Further links:
Share your models, scripts, workspaces, and more with the Altair Community.
