Overview
Organize Components into an assembly structure based on the normal orientation and position of contained surfaces. This is useful when dealing with a huge amount of structured surfaces as common in shipbuilding and aerospace.
1) run the script
2) select components to organize
3) set to 1 if global coors should be used first
4) select reference surfaces to organize by, keep empty to proceed
Limitation
Works only for components that contain surfaces in one plane.
Functionality
Geometry Model/Analysis
Subfunctionality
Assembly Midsurface
