Overview
It is difficult times where there is a need of adding tempnode to CG available in the part inertia card in Dyna Profile. This macro helps to do it automatically by adding the nodes at those available CG info and tells you how many parts are assigned with CG. Coordinates information can be seen if you run this macro using command window.
Usage
Run the script once, it will added temp nodes at CG locations.
Limitation
Useful for only dyna.
Functionality
Model/Analysis
Subfunctionality
Model Setup
Interface
LS-Dyna
