I have defined a surface between 2 Volumes(in Hypermesh) . I want to provide Heat Flux on this surface.(I know how to do it)
However when i export the mesh file into Acuconsole 21, there are 2 surfaces created (as seen in image). Should i provide the heat flux value to both or turn off the boundary condition for 1 of it.
MCU1 is the name of Surface while ALPLATE AND TETRA are 2 volumes on both side of surface.
