This macro helps in creating washer split for multiple holes at a time with a given off set value.
Run tcl/tk script-->specify a offset value proceed.
GUI
Panels
It comes with an error. could you explain how to use it properly?
Thanks!
error saying : No circle found
hm_getbestcirclecenter: No circle found. hm_getbestcirclecenter: No circle found. while executing "hm_getbestcirclecenter lines 2" (procedure "washer_split" line 17) invoked from within "washer_split" (file "Multi_washer_split.tcl" line 56) invoked from within "source {Multi_washer_split.tcl}" ("uplevel" body line 1) invoked from within "uplevel #0 "source {$file}"" (procedure "::HM_Framework::p_FileLoad" line 60) invoked from within "::HM_Framework::p_FileLoad 24" (menu invoke)
Share your models, scripts, workspaces, and more with the Altair Community.
