I have a huge model which I need to run Acusolve in parallel on 2 separate systems. I have no idea about parallel computing in Acusolve. Please help. TIA
You'll typically get best behavior on Linux and with the systems having a high-speed interconnect, like infiniBand. Do you have a cluster with multiple compute nodes - or is it really two separate standalone 'boxes' you want to connect? Please describe the systems you want to use - OS, CPUs, memory, interconnect, etc.
