Move a Marker on a Rigid Body
Danielle_21252
Overview
Locate and orientate a marker to the same location and orientation of a second marker when a calls this sensor evaluate subroutine is called.
This sensor evaluate, SEVSUB, function places the j-marker at the same location and orientation as the input "i-marker".
- Create a sensor in MotionView to evaluate a user subroutine when the sensor is triggered.
- In the sensor-response panel check "Evaluate Expression".
- In the drop down menu select "USER"
- Next to the "USER" enter "User(,,)
- In the sensor-response dll tab, select the local file location for "relocate_marker_03Nov14".
- In the drop down menu for "Function Type" select "Python"
- In the "Function Name" text box enter "relocate_marker"
- Copy the information from step 4 to the text box for "User Expr"
Limitation: None
Functionality: MDL, Multi-Body Dynamics
Subfunctionality: Model building, XML format
Interface: XML Format
