Overview
The script allows you to Identify holes if any on a surface and then creates a temp node at the hole center.
Well you can save the script at your working directory, and source the code through the Command Window. Once sourced: 1. pick the surface you want to find holes on, the temp nodes at the hole center will be created.
Limitation
Limitation: None know: small script
Functionality
Geometry, Meshing, Utilities
Subfunctionality
2D Meshing, Editing
