Export Stress Results Components to CSV
Chayan
Chayan
edited April 2022 in Altair Exchange
Overview
This macro provides a GUI to select the Nodes in order and export the same in *csv file. It also applies contour in all 3 directions and exports them resp onto an excel file. They needed also to display the grids then pick on the screen and export them in the order they pick the nodes (Ver. 11: HWDesktop SA1-101)
1. Load the tcl file in HV which launches a GUI.
2. Using the Node selector, select nodes the order you intend to write out.
3. Select the ouput CSV file location.
Limitation
Node selection "By ID" does not currently seem to work Hitting the Close button freezes the panel area and instead the user can just click on any other button in panel area to deactivate this tool
Functionality
Results
Subfunctionality
Query
Interface
No Specific Interface
Comments
  • srinivas rallabandi_21059
    srinivas rallabandi_21059 Altair Community Member
    edited July 2022
    its only Exports the Node ID,X,Y,Z . The Query ( Stress/Displacements) are  not exported
Welcome!
Welcome!
